STEREO WIRES CUT AWAY BIG BIG MESS PLEASE HELP
what it is i do know the previous owner at some point had a dvd player wired up and used the phono leads instead of the speaker wires from the dvdplayer. atm all wires have been cut from the original white connector. it has the power wire from the stereo wired to a red wire from the car and the earth to the brown and obviously the aerial as a earth when plugged in.this gives the unit power, but no phono leads or speaker wires are wired anymore. all of the wires are as follows blue, brown, red, yellow, white, green and white, green, black, red and black, pink and blue, another white, another red, another green and another brown. please will someone please tell me how to get this thing alive
Try this it is the wiring diagram for the active system (the one with the amps) looking at the wire coluors its the one you have
hope this helps
Paul
thanks for the diagram, thought would have helped maybe its just me doing everything wrong. im wiring the fl+ from head unit to the white wire the fr+ to the red wire and so on, no joy HELP i want sound
- Deceased Member R.I.P
I once made the mistake of cutting the plug off the active sytem in my car (not knowing it was an active system at the time)
Thought it couldn't be too hard to figure out.
All I can suggest is that if you're putting in a conventional HU, find your switched live, constant live, aerial feed, put in your own earth and run your own speaker cables through.
Totally different kettle of fish of you have a passive system.
My 2p all the same.
(and I see thet you 2 guys are from the NW, and we're yet to be introduced)
My 2p all the same.
i know what you mean but dont fancy stripping everything down to rewire. its got to be set up like this for some stupid reason lol
Re: STEREO WIRES CUT AWAY BIG BIG MESS PLEASE HELP
I have fitted more car stereos over the years than I care to remember.98duffa wrote:i know what you mean but dont fancy stripping everything down to rewire. its got to be set up like this for some stupid reason lol
But if you're dealing with the active system, and have no connector to fit to the Autoleads loom, you're going to get all manner of interference and screaming (take it from one who knows)
In fact I got so annoyed with the system in my old car, that its still sat in it, and my new car has been left with the system that Mr T put in there in the first place.
But I digress, if I was to be doing my old car over again, I'd just bypass all the amps, and go straight to every individual speaker.
I have recently fitted a new head unit in my 2, managed to get it working using the built in amps. You have to use the pre amp outs on the back of your head unit to get them working. The red and white wires are for the front two speakers and the blue and brown ones are for the rear. Let me know how you get on. It is quite easy once you know where the wires are.
Forget to say, the amp remote wire on your new stereo needs to be used to switch the amps on when you turn your stereo on.
hi how can i tell if my mk2 rev 1 is an passive or active setup any help would be very welcome
I have the problem of an active system with no connector block, is it easy to run new speaker wires to bypass the amp??
The plug for an active setup is the white one and you can look in the box behind the passenger seat for the sub. I think they're all an active system but only the GT model had the sub. It is easy to bypass the amp. You just have to take the side panels off and the door cards to get to the speakers to solder new wires on. For the door speakers I put little holes in the grommets and run the wires outside of them.
