Automatic transmission fluid
Topic author - Posts: 4
Hi
does any know how many litres a automatic transmission holds on a mk2 toyota mr2, 3sfe engine non turbo?
thanks
thanks
Re: Automatic transmission fluid
It pays to drain, refill, drive a bit and then repeat. This helps to replace fluid trapped in torque converter. Add another litre if you drop pan to replace filter. Not sure if this is really necessary as mine was spotless at 150km but wasn’t a difficult or expensive job.
On type of fluid I swapped to a full synthetic which met the ATF spec. This was on my gen3 NA.
