engine (coolant) drain plug location?
I'm going to try and flush the rad and replace the coolant before the cold snap sets in next week.
So, where's the engine coolant drain plug? I know it's on the block somewhere, but which side and whereabouts?
Re: engine (coolant) drain plug location?
Theres a drain plug on each ally pipe to the rad under the car closer to the engine end.
There's a drain plug on the thermostat housing also but I'd probably take the pipe off instead
+1MRturboTom wrote:Theres a drain plug on each ally pipe to the rad under the car closer to the engine end.
I tend to drain from the rad and then use a hose in the pressure cap access to flush the pipes until clear water appears. then undo the heater matrix bleed and do the same.
Saves lying under the car and messing with undertrays etc- if you have access to ramps then I would drain from the pipes as well.
Use concentrated Halfords advanced which then allows for clean water left in the system after flush. Then top up with a 50:50 mix and bleed. Usually done this way after RAD change so have access to both rad pipes which makes flushing easier
- Years of MR2 Ownership: 4
The engine block drain plug 14mm is on the rear facing side of the block.
See this guide (there is a photo showing the location of the bolt)
http://www.mrtwo.net/mr2modproject/serv ... flush1.htm
Wow, that is a good guide! Thanks! Won't be using Evans, though!
If the lower covers haven't been off for a while you will probably snap a few bolts. Built time into your day to drill and re-tap the brackets. If planning on leaving that to another day you will need some cable ties to resecure the covers.
Well, a recurring bate of alternatoritis has pretty much put that on the back burner. The good news is that I discovered that the n/a Rev1 has a pretty near new radiator (I just pulled off the top radiator mounts to paint and discovered that) so I can just swap that out. In the meantime, I've emptied a little water with the mityvac and popped in some of Bluecol's universal anti freeze.
Let's just hope the alternator on the n/a car is worth pulling out -- it's a job I hate doing. Was looking forward to doing some welding this weekend, too.........
