Engine Fixings Torque Settings (MK3 1.8vvti engine)
The forum Administrator has chosen to advise you that this topic is 3 years and 8 months old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
IanMorphecusStevens
Years of MR2 Ownership: 5
Real Name: Ian
Post by IanMorphecusStevens »
Hi
Does anyone know where I can get official torque settings for the MK3 1.8 vvti engine?
There are a few forums that come up in a Google search but I don't know these people and have no idea whether the info will be correct & accurate etc.
This has not been an easy job and I don't want to take this engine out ever again!!!
I have emailed Toyota direct and have spoken to my local dealership but other than pestering their mechanics to go find out the data sheets, which seems a bit unreasonable, I have had no luck.
v grateful for any advice but please don't just text back a load of figures, I'd like to have official data sheets if possible, so I can be sure I'm rebuilding as perfect as possible - I'm an engineer, not a mechanic, we panic if things aren't perfect!!!
cheers,
Ian
Has thanked: 45 times
Been thanked: 120 times
Re: Engine Fixings Torque Settings (MK3 1.8vvti engine)
Welcome to the club :th:
You can download the MK3 BGB, A.K.A. "The Big Green Book" or "The Toyota Repair Manual" from here
https://www.mr2oc.co.uk/download-cats/c ... 2-mk3.html
it contains the info you need in the Repair section ;)
IanMorphecusStevens
Real Name: Ian
Cheers! I’m out at the mo so will download when I return home - thanks in advance!
Return to “MK3”
