Engine Poly mount Sizes
As title does anyone the size required for both the front and rear engine mount bushes for a MK2 Rev 3.
Re: Engine Poly mount Sizes
Checking this out
http://www.driftworks.com/powerflex-bus ... 89-99.html
the rear one is 79mm
the front can be one of three 73mm, 79mm or 83.5mm
I'm guessing the 83.5 will be tubby and the 73mm may well be the FE, so that'll leave the 79mm for the N/A, but someone might have one kicking around they could check for you.
- MR2's Owned: 10
I would measure yours to be honest. It should be
73mm na
79mm turbo
83.5mm trd
but a lot of cars have had them changed (I had to send my 83.5mm mount to powerflex for them to make the mould when I ordered 79mm without checking) and the rear ones can be 83.5 as Jim found out.
73mm na
79mm turbo
83.5mm trd
