Idle/rev/odd problem
Hi guys, had the mr2 back on the road for about a month now, has been doing pretty well by me, but got this problem which is very embarrassing and annoying.
Basically, its more when its cold, and its got worse the more i've left it (as always)
When driving, I now often get an engine light, car will usually continue at the speed im at keeping that I leave the right foot exactly where it is, if i let off its a little lumpy coming down, if i try to accelerate it will bog down really badly.
Also it will sometimes not idle or idle very very low (around 400-500 and can stall often)
Occasionally it will decide to idle at about 2700, and this lasts for ages, is very very embarrassing due to how much attention it attracts.. Also it struggles to start (ish) when cold, but after being properly warm for a fair amount of time it seems to be A-ok!.
Please help :'(
Please help :'(
Re: Idle/rev/odd problem
Which model and revision do you have?
Hmm based on the symptoms it could be a number of things to do with the Coil pack, Dizzy cap, plugs or cracked ht leads, damp in any of these components will give you serious running issues especially a crack in the coil pack "which is quite a common fault on these cars" and see's as you only get it in the morning then might be a good idea to have it look at it.
High idle may well be idle valve or a small vac leak
I got the code 2-2, that was the only one, I doubt its rotor arm dizzy cap or ht leads because they are all pretty new, will have an inspection. Idle control valve was also recently changed as I thought mine must have been faulty, so don't think its that.
If you've read it correctly, that's 22, which is a water temp sensor or circuit related. I think there are a couple of water temp sensors, one of which tells the ECU to enrich the A/F mixture while the engine is warming up. This may explain your cold start and idle issues.
Remember, there may be more than one thing wrong.
It sounds like it made sense, and im pretty sure I read it right, it was the only code, and I sat there and confirmed it about 5-6 times. I know my thermostat needs changing and I already have a new one, as when it has just about got to normal temp if I put my foot down the coolant temp gauge can drop to nothing. Will get my friend Mechanical Steve to have a look.
Make sure you come back and let us know what the problem was and how you resolved it.
ECU temp sensor (green sensor on water outlet) £15 from Camskill. 5 minute job. Just needs a little coolant topup afterwards. Job done.
Oh and check the wiring connector too for corrosion.
