Track Rod Ends - Same across GE and GTE?
Are the track rod ends between the GE and the GTE the same? The only difference being PAS and non PAS??
I think I've tracked the part number down to 45503-19145 (could be wrong) which Toyodiy says is the same for all MK2s Jap and Euro 89-99, but as stated above, I'm sure there is a difference with PAS. (Again I could be wrong, the PAS and non PAS part look the same, just different prices).
Fensport seem to sell the same part for both cars, but they don't list a part number, so can't be 100% sure.
Many thanks in advance.
Re: Track Rod Ends - Same across GE and GTE?
Pas and non pas iirc is different, all sw20 same otherwise
The 45503-19145 is for the rack end Rick. They do differ between the PAS and non PAS racks but the track rod ends (45046-19195 RH, 45047-19075 LH) are the same.
The PAS rack end is 45503-19145 and the non PAS is 45503-19165.
Many thanks to both of you.
I'll order the part and the car will be back in tip top shape by next weekend.
