Where to find the right stereo harness?
Topic author - Posts: 12
Hi again guys. I managed to find the instructions on cracking open the console to get the stereo out, but now I've got the problem of getting my new stereo wired in. Does anyone know where is get the right harness to connect a Sony MDX-C7900R unit to my MK2 standard plug?
- Years of MR2 Ownership: 21
- Been thanked: 119 times
Re: Where to find the right stereo harness?
Moved to the correct forum. Try searching in this forum and have a look in KY2 https://www.mr2oc.co.uk/know-your2/mk2/ ... erior.html
Thank you.jimi wrote: ↑04/06/20 21:14 Moved to the correct forum. Try searching in this forum and have a look in KY2 https://www.mr2oc.co.uk/know-your2/mk2/ ... erior.html
peter walker wrote: ↑04/06/20 22:39Is this the correct one?:
https://www.halfords.com/technology/car ... 82053.html
That one is for the MK1, the one you need will depend on whether your car has an active or passive system. Try here
https://www.mr2oc.co.uk/know-your2/mk2/ ... ystem.html
https://autoleads.co.uk/
https://mr2-ben.co.uk/categories/92
Great! Thank you! I've ordered both types to be surejimi wrote: ↑05/06/20 2:27peter walker wrote: ↑04/06/20 22:39Is this the correct one?:
I got it working! I had ended up having to do some soldering because the harness they sent me was a badly repaired salvaged part. I also had to replace some fuses because the bad repair caused a short. But it's working now!
I did a little hands on video if you're interested in what is like to have minidiscs:
Which harness worked ? Active or passive? You might find this useful https://www.sony-asia.com/electronics/s ... Mdx-c7900r
The active one.jimi wrote: ↑11/06/20 16:21 Which harness worked ? Active or passive? You might find this useful https://www.sony-asia.com/electronics/s ... Mdx-c7900r
