Which spark plugs for a rev 3 turbo?
Hi planning on doing a service to my rev 3 turbo and wondered what spark plugs I need my current mods are greddy smic blitz nur spec exhaust boost controller and blitz induction kit I understand there is different heat rating for plugs ? Also would anyone recommend a good oil to use ? I'm not sure if its old oil causing my car to give off black smoke when planting my foot does any advice welcome many thanks
Re: Which spark plugs for a rev 3 turbo?
Oil smoke is generally blue. Won't have anything to do with the age of the oil.
My guess is that it's overfuelling for some reason (that's what generally causes black smoke). Do get it looked at -- overfuelling can cause significant oil contamination and generally does nothing good.
For plugs, see here. 7s should be fine.
Most likly the seals on the turbo are on the way out. Oil builds up in the intake when your just cruising due to the vac in the intake and then hitting boost just blasts the oil through. Ran mine like this for years however the excess oil deposits a strange buildup on the spark plugs.
Stay with the stock Platinum or Iridium 6 range plugs unless you have upped the boost significantly then go for a 7
Ngk iridium grade 6 or 7s but I'd fit 7s personally.
£30 delivered from jp4mance iirc
Hi guys thanks for the reply very helpful as always plugs are ordered I went for 7's ,
How can I sort the over fueling ?
First make sure it is! Ideally an AFR guage (or a 3 gas meter) at a rolling road. If it is oil getting past the turbo seals (or anything else, for that matter) it should be pretty obvious from the smell on a RR.
If it is overfuelling, the "why" is a more complex question. I'm a long way from understanding the Mk2 ECU!
they do overfuel on boost as standard....
upping boost doesnt seem to lean alot out (it has more fuel than the ct20b can throw at it)
saying that, you really shouldnt be seeing alot of smoke, i cant notice any on mine (though im sure there must be some high in the revs)
check this afr plot even at 285hp (not mine), pretty much matchs what im seeing on my wideband gauge.
......Rev4 Tbar Turbo......
______Azure blue______
____Project, click me____
No smoke from mine, either, although the pipes show a fair bit of soot (must clean the car, must clean the car.........).
Thanks for your help guys i think ill ask Ryan at 2bar to have a look when I get round to getting an apexi fc
That bloody dyno plot gets everywhere! lol
The pink line is the rev3 ECU
