Are Toyota body and glass seals reusable?
_Al_
Years of MR2 Ownership: 15
MR2's Owned: 7
Real Name: Mr Misfire
Has thanked: 108 times
Been thanked: 17 times
Post by _Al_ »
With extensive amphibian assistance (thanks TLF!) I’ve found the part I need. The question now is “should I install it”? Reason for asking is that at least part of it is self adhesive by the look of things, and I suspect it'll have to come off again when the car gets a (badly needed) respray.
Not keen to spend £££ on a bit of rubber then chuck it away soon after..
Anyone know definitely either way?
Cheers!
Has thanked: 47 times
Been thanked: 120 times
Re: Are Toyota body and glass seals reusable?
Which seals ?
Years of MR2 Ownership: 16
MR2's Owned: 6
Been thanked: 31 times
Post by TonyleFrog »
This one.
PNC# OEM Part Nr
62381A 62381-17042 01 09.1993 - WEATHERSTRIP, ROOF SIDE RAIL, RH SW20..CP
https://toyota.epc-data.com/mr2/sw20/152204/body/6104/
_Al_
MR2's Owned: 7
Post by _Al_ »
:facepalm: Ah yes, meant to post the same pics as my project thread
Is that this one ?
Page BO32 from 1993 SW20 Repair Manual.jpg (41.68 KiB) Viewed 186 times
MR2's Owned: 6
:th: The top one (w/o T-bar roof).
It will all depend on if you can get the adhesive part to come off without damaging the seal.
I've removed similar seals from cars with the help from a hair drier to warm the adhesive, then cleaned all the old adhesive off of it and used a decent quality double sided tape to reapply it. It's quite a big robust seal and being new will help ;)
_Al_
MR2's Owned: 7
Post by _Al_ »
Thanks gents… Had no time to act on this. Norrovirus in the house :facepalm:
Hope there's not to much
:puking:
_Al_
MR2's Owned: 7
Post by _Al_ »
It seems that there’s enough to go round… :hide:
MR2's Owned: 6
Sorry to hear that. :sad:
Norovirus (aka Norwalk) is highly infectious but doesn't normally last long (1-3 days). Drink plenty of fluids (rehydration solutions). Virus shedding can continue after symptoms subside so don't be in a hurry to return to the workplace or send the kids back to school/pre-school/playgroup.
_Al_
MR2's Owned: 7
Post by _Al_ »
Yeah we’ve all stayed well away from everyone. Still feeling lethargic now. ‘Orrible bug!
I’ve bodged it, stuffed some “shop towel” being the seal to see if that’ll push it up against the glass properly. Did same same with my 350z. Worked a treat for over a year till I sold it.
