Calling all Engine Guru`s.
Considering a turbo or V6 conversion then use this forum
The forum Administrator has chosen to advise you that this topic is 4 years and 1 week old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
mattler
Has thanked: 1 time
Post by mattler »
Hi guys.
I`m in the process of buying an MR2 which has had rather a lot of work done to it.
If possible could you tell me if the mods that this guy has done are regular/safe/reliable.
It looks good on paper but I know all too well from my Evo days that throwing money at something doesn`t always make the best job!
For info its last Dyno made 350BHP @ 1.1bar
Engine spec as follows.
ENGINE:
-BUILT BOTTOM 3SGTE
3rd Gen turbo engine with anti lag system.
-ATS racing turbo kit
-Garett GTX28 Gen2 turbine 275hp-550-hp capable
-TRD by Motul 5w40 since day 1
-CP oversized forged pistons 97mm 9.0:1
-JE Forged piston rings
-Eagle forged conrods
-Acl Forged engine bearings
-Cometic 87mm Steel gasket
-ARP head studs
-ARP main stud
-ARP con-rod bolts
-TRD 1.2 bar radiator cap
-TRD high tension wire
-TRD oil cap
-HKS SQV4 BOV
-Project MU magnetic drain bolt
-Walbro 255 LPH fuel pump ( changed 11/18 )
-Mishimoto complete silicone hoses
-Greddy oil catch
-Greddy Side mount intercooler
-Full stainless charge pipes / intake pipes
-Apex-i 3 row aluminum radiator
-Apex-i air intake inlet
-Apex-i air filter
-6 row oil cooler kit
-3” Stainless steel straight exhaust
-3”Stainless steel down pipe
-Custom aluminum engine shroud and exhaust fan for cooler engine
-Custom aluminum engine lid will (include stock lid)
-Custom intercooler sprayer
-Thermotec cool it wrap down pipe, exhaust and Intercooler charge pipes
-OEM fuel filter (11/18 changed)
ENGINE MANAGEMENT:
-Adaptronic E420d
-AEM fail safe / wide-band
-GFB G-Force 2 EBC
-Defi Racer Boost and Fuel gauge
-Blitz turbo timer
MR2DI4
Years of MR2 Ownership: 23
Real Name: 2023 i30N Hatch 6MT
Been thanked: 1 time
Re: Calling all Engine Guru`s.
Post by MR2DI4 »
Have you taken it for a drive ? Big difference from whats on paper to the way it actually drives.
telgnal
Post by telgnal »
Et le prix ?
SonicSW20
Been thanked: 6 times
Post by SonicSW20 »
87mm pistons I assume, not 97mm?
mattler
Has thanked: 1 time
Post by mattler »
Unfortunately no chance for a test drive until I get home and go to complete the purchase.
I was more wondering if this is a kind of "regular" build?
mattler
Has thanked: 1 time
Post by mattler »
The other thing that slightly concerns me is the clutch. Although its only done 2300miles as it was fitted with the new engine. Its only a stock clutch.
Any opinions on whether this is just totally inadequate or should I get the life out of it then go for uprated?
Return to “Engine Conversions”
