Welcome! There are plenty of breakers but I’d be trying to ensure I knew what the fault is before buying anything
Anniversary Aerial Problem
Topic author - Full Member
- Has thanked: 108 times
Re: Anniversary Aerial Problem
Welcome to the club. Have you read this article ? may help with your aerial problem https://mr2oc.co.uk/know-your-2/mk2/mk2 ... erial.html
I have read the article, though it wont help as I discovered that the inside plastic toothed pully has snapped in two, motor looks pretty bad too (but still works).
Ive sent 20 messages to various MR2 mk2 breakers though no one could help me.
- Has thanked: 33 times
have you tried tcbparts ?
- Real Name: Alan Byrne
- Been thanked: 21 times
You can buy a replacement mast off ebay as I bought one ages ago and was easy enough to fit. I do have a spare rev1/2 electric aerial (genuine toyota) that you can have. The mast is bent but everything else is good. Cheers
- Real Name: Andy
- Has thanked: 1 time
I have just repaired mine. I stripped the unit down, washed out all the old grease and reassembled with fresh grease. I purchased a replacement mast from ebay but it was rubbish, it was too thin so the gears just slipped over the teeth, it was even thinner than the original worn out one. In the end I bought a replacement genuine Toyota mast from GT4-Play and it now works perfectly.
https://imgur.com/a/x56zVif
its not the mast he needsBYRNEY1984 wrote: ↑07/05/23 10:34 You can buy a replacement mast off ebay as I bought one ages ago and was easy enough to fit. I do have a spare rev1/2 electric aerial (genuine toyota) that you can have. The mast is bent but everything else is good. Cheers
