broken key
The forum Administrator has chosen to advise you that this topic is 9 years and 2 months old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
suchafunkymonkey
broken key
Post by suchafunkymonkey »
The key has been snapped in half, with half the key still in the ignition barrel. The engine is off but i cant turn the ignition in order to get the barrel out.
Any suggestions? Ive tried fishing the broken out but with no success.
Years of MR2 Ownership: 16
MR2's Owned: 6
Been thanked: 31 times
Re: broken key
Post by TonyleFrog »
http://www.walkerlocksmiths.co.uk/cylin ... extractors
An alternative d-i-y solution. Go to B&Q and get a pack of spare fretsaw blades.
Snap one end off with pliers (tip: the teeth need to be pointing backwards)
Wiggle blade into the barrel. Twist slightly and pull. Borked end should come out.
The proper tool will do a better job though.
Return to “MK1”
