Camber adjustment
Use this forum to find out what fits and to share fitment information and images.
The forum Administrator has chosen to advise you that this topic is 9 years and 3 months old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
BenMr2Essex
Real Name: Ben
Camber adjustment
Post by BenMr2Essex »
Just a passing thought really...
But will be getting 4 wheel alignment done soon so am just getting prices from places.
One place done free measurement and £10 adjustments for toe but what really got me was the £50 to do rear camber?!
Why on earth is it more expensive? Is there that much more to adjust? I thought it was one adjustment on either side?!
Ben
MRturboTom
Years of MR2 Ownership: 6
MR2's Owned: 9
Re: Camber adjustment
Post by MRturboTom »
You need to take all the weight off, wheel off, adjus, refit, put gauges on and re read.
Effects toe massively.
But to adjust the toe, it's gauges on and tweek the rods, simple.
jimGTS
Years of MR2 Ownership: 9
Post by jimGTS »
possible to set your own camber (with bolts and/or adjustable topmounts) and let the garage do the toe?
or will camber always need tweaking professionally?
http://www.mrtwo.net/mr2modproject/mod/ ... hbolts.htm
......Rev4 Tbar Turbo......
______Azure blue______
____Project, click me____
BenMr2Essex
Real Name: Ben
My rears have camber already but by looking at rear from a slight distance I'd say too way, prob way to much..
But toe is out front and rear. Not so much the front.
Is there anyway to measure the chamber myself?
Chamber is done via the cusco suspension, so not sure if there would be indicators or something?
MRturboTom
MR2's Owned: 9
Camber gauge, but the car needs to be on a 100% level surface or else it'll be all messed up.
BenMr2Essex
Real Name: Ben
Cheers Tom. Been doing some research with the help of Stu and think we found something that looks like it can calibrate its self to the floor level? Maybe, maybe not. But we shall see soon
MRturboTom
MR2's Owned: 9
I just put a spirit level on the engine lid to find somewhere flat.
Measure the camber on the wheel, then take wheel off and measure camber on the disc. Work out the adjustment required, adjust and recheck with wheel on.
jimGTS
Post by jimGTS »
MRturboTom wrote:I just put a spirit level on the engine lid to find somewhere flat.
cool
yeh was gona say soon as you jack the car up taking the wheel of youll change the angle.
but as you say if you know both results, you can apply the adjustment to the disc.
something like this do the trick?
http://www.ebay.co.uk/itm/SAVE-GARAGE-C ... 53ec0d0fdd
BenMr2Essex
Real Name: Ben
Have a look at 'clinometer' on the App Store. I do believe you can calibrate it to the floor angle first... Which makes life easier lol
stuMR2lee
Years of MR2 Ownership: 7
MR2's Owned: 6
Real Name: Stu
Camber adjustment
Post by stuMR2lee »
BenMr2Essex wrote:Have a look at 'clinometer' on the App Store. I do believe you can calibrate it to the floor angle first... Which makes life easier lol
That's the theory!
MRturboTom
MR2's Owned: 9
cool
That's what I use and the alignment printout I get after I get all the toe done shows its spot on
stuMR2lee
MR2's Owned: 6
Real Name: Stu
Post by stuMR2lee »
Not having coilovers I may be missing something but it seems the camber adjustment on Ben's car is by the top plates. I appreciate that on some cars it's via the bottom of the strut though, possibly with crash bolts.
If adjustment is just by the top plate I assume the wheel doesn't need removing?
jimGTS
Post by jimGTS »
i would have to guess so, tom knows more about these things than i.
you would still require a way to measure your wheel camber though. as the notches/lines on the topmount probably dont mean a great deal, more a visual reference but no actual numbers.
i have adjustable topmounts AND camber bolts!
though looks like all my camber has been achieved through the bolt, not the topmount.
why, i couldnt tell you? anyone?
hence ive joined the fold as i like to learn new things. and if camber adjustment is as expensive to do at a garage as ben says, and requires people messing with my wheels, if i can do the work myself i will.
stuMR2lee
MR2's Owned: 6
Real Name: Stu
Post by stuMR2lee »
Yep, I'm keen to understand it a bit more too.
I have the Trackace gauge which seems pretty repeatable for toe measurements. We've also experimented with the string/axle stand method of setting the thrust angle and checking rear toe. Proper race car stylee. I'm looking to see how close we got when I get the alignment checked next week on a Hunter system.
Return to “MR2 Wheels and Tyres”
