CO emisions
The forum Administrator has chosen to advise you that this topic is 5 years and 2 days old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
einsvonzehn
CO emisions
Post by einsvonzehn »
Having the yearly test my emmisions have risen from 0.3% last year to 0.760% having driven 2000km in the year. The tester said it wasn't a big problem but I have to get it reduced. Any ideas to why the increase. :confused1:
oVerboost.
Re: CO emisions
Post by oVerboost. »
Did the MOT tester get the exhaust really hot? Was it parked up before the test took place?
Could be the catalyst breaking up, if it's original or it could well be the lambda sensor starting to fail. Other than those items, if it's serviced correctly there isn't much else it could be on these cars.
SegaAges
Real Name: Mr Sega
Re: CO emisions
Post by SegaAges »
Had this on my 2 as well, one year it hardly registered on the computer for Co reading the next year the Co was off the chart the garage said this moter is running really rich, I spend days testing everything, even had the injectors out encase one was leaking but nothing and all was well with in spec, decided to put another cat on and that sorted it.
Thing about the Mr2 is the cat is so far away from the engine so the engine needs to be really hot before the tester shoves the prob in, it cools down very quickly on idle I noticed it when I was putting a temperature gun on mine to make sure the new cat was working properly.
