Gearbox upgrade
Gearbox upgrade
Hi all
Not sure if anyone on here can help, I have the same C60\64 6 speed gearbox in my Exige as you guys run in the VVTLi MR2 I am suffering from gearbox failures (3rd Gear) apparently due to the 300hp I'm running. Do any of you know of a stronger gearset that actually works for this gearbox for high HP?
Thanks in advance
Adrian
Lotus Exige S
Thanks in advance
Adrian
Lotus Exige S
Re: Gearbox upgrade
Over 300hp and 200lb/ft of torque is certainly good till this happens
http://www.youtube.com/watch?v=PbG8RlIckfk
Here is a clear lap early on the first day while I was still learning the lines so I was being a girl through au rouge and a couple of the other corners
http://www.youtube.com/watch?v=t61OMLmYd1A
