Na brake calipers
The forum Administrator has chosen to advise you that this topic is 3 years and 4 months old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
John harle
Na brake calipers
Post by John harle »
Just wondering if anyone knows. My mr2 is a g limited import and I need some new pads and discs. I have had the calipers off and it has twin pistons on the front. Is this normal for an na car? Just so I can order the correct parts thanks.
SonicSW20
Been thanked: 6 times
Re: Na brake calipers
Post by SonicSW20 »
Yes, its normal.
For UK, LHD Europe, and Japan market SW20's, the brakes on the NA and Turbo are broadly the same. The only differences come with revision. Rev1's have the smaller brake setup, Rev2-5 has the larger brake setup.
Any information you see regarding turbos having different brakes to NA's is relevant to North American market cars only.
