Quieten gearbox noise - Rev 2 Turbo.
Hello everyone!
I've recently been getting my 2 working again since I've taken it off the road and have replaced or fixed bits recently. After changing the gearbox oil since it was old and literally a little over 2 pints came out (not exact but rough idea), drained and topped up with the recommended oil on this site.
Since then all gears whine like a b*tch. I mean, it's really loud it can over power the engine noise between 1500rpm up to 3800rpm or so? More so in gears 3 - 5. I'm planning on getting a replacement gearbox likely late next year and get clutch done as well but would like to know if there's something I can add that someone has used to it to help quieten the whining down a little.
No sawdust or banana peel suggestions please!
Re: Quieten gearbox noise - Rev 2 Turbo.
I find the whining disappears when I leave the Mrs at home... Give that a go
Hahaha! Fantastic response but not quite what I'm looking for
I'd think the damage has been done. Replacement or rebuild time, I think.
Remember, that noise is a symptom of significant wear. Were the box to lock up or explode at 70mph you'd have almost no control of where the accident ended.
2 squirts of grease can help into the oil
Would this thicken the oil or something? Speaking of which, is there a thicker oil or alternative like Redline mt90? I think people on here say helps with gear changes and what not do the trick?MRturboTom wrote:2 squirts of grease can help into the oil
Yes, very true. Definitely going to get a replacement unless repairing is a viable option. Was hoping for a way to dampen the whining to not be as bad for the next few months until I get it done.fingers99 wrote:I'd think the damage has been done. Replacement or rebuild time, I think.
Annoyingly it wasn't anywhere near as bad before I swapped over the oil and where I've got one bucket to collect all oils, I can't try and reuse with the new stuff
I put redline in mine and noticed a difference straight away - saying that mine was still pretty tight as it had only done about 70k miles. Remember a thread saying that comma gear oil was as good as redline and not quite so expensive - never heard of the grease application before - but think I understand how it could work. Which gear oil did you use?Shaleskin wrote:Would this thicken the oil or something? Speaking of which, is there a thicker oil or alternative like Redline mt90? I think people on here say helps with gear changes and what not do the trick?MRturboTom wrote:2 squirts of grease can help into the oil
I put in 75/90 gl4 castrol stuff from Halfords...peteV6R5 wrote: I put redline in mine and noticed a difference straight away - saying that mine was still pretty tight as it had only done about 70k miles. Remember a thread saying that comma gear oil was as good as redline and not quite so expensive - never heard of the grease application before - but think I understand how it could work. Which gear oil did you use?
http://www.halfords.com/webapp/wcs/stor ... yId_255220
^ That's the one. With this grease method is there a particular brand or type best used?
A bearing grease, or lithium iirc. Only need a tiny bit so I'd ask other locals for a bit possibly?
Alright, cheers for that. Will have a wonder to the locals this weekend. Then have a look for a replacement box. Speaking of which, are the gear ratio's the same from rev 2 to rev 3+?MRturboTom wrote:A bearing grease, or lithium iirc. Only need a tiny bit so I'd ask other locals for a bit possibly?
I believe the e153 box is all the same just the diff differs between lsd and open.Shaleskin wrote:Alright, cheers for that. Will have a wonder to the locals this weekend. Then have a look for a replacement box. Speaking of which, are the gear ratio's the same from rev 2 to rev 3+?MRturboTom wrote:A bearing grease, or lithium iirc. Only need a tiny bit so I'd ask other locals for a bit possibly?
That's good to hear so will start looking about for one. Thanks for your help.MRturboTom wrote:I believe the e153 box is all the same just the diff differs between lsd and open.Shaleskin wrote:Alright, cheers for that. Will have a wonder to the locals this weekend. Then have a look for a replacement box. Speaking of which, are the gear ratio's the same from rev 2 to rev 3+?MRturboTom wrote:A bearing grease, or lithium iirc. Only need a tiny bit so I'd ask other locals for a bit possibly?
