Rev3 Turbo - Charcoal Canister VSV
Topic author - Posts: 103
Rev 3 Turbo. Can someone tell me what the actuator/sensor is that is mounted on a bracket off the charcoal canister? Also does anyone have a photo of how it's supposed to be mounted they could post up? The one on mine has been bodged on with a couple of zip ties and I want to put it right.
- Years of MR2 Ownership: 2
Re: Rev3 Turbo Actuator
There a labelled diagram in know your 2
Mr2 G limited (gt-s engine) broken but fun
Mr2 uk 156 bhp - in bits
Mr2 gt 170bhp - with the parents
http://mr2turbo.wordpress.com/
If its broken hit it with a hammer if its still broken get a bigger hammer
Um... post a photo of what you mean. Unless you're talking about the charcoal cannister's VSV then you could far too easily be talking about an aftermarket boost solenoid or something like that?
I think it is the VSV for the charcoal canister, it's the rusty looking thing with the blue plug connected to it. Planning on tidying up the engine bay and want to source a replacement with the correct mounting.shinny wrote:Um... post a photo of what you mean. Unless you're talking about the charcoal cannister's VSV then you could far too easily be talking about an aftermarket boost solenoid or something like that?
Well it's not the turbo wastegate actuator as the thread title suggests, so I'll change that for you
Thanks that title didn't read right, what I meant was Rev 3 Turbo - Actuatorshinny wrote:Well it's not the turbo wastegate actuator as the thread title suggests, so I'll change that for you
Re: Rev3 Turbo - Charcoal Canister VSV
unfortunately they all sit that way.
its like there only "stuck" on on the bracket as standard
ive seen plenty held on by zip ties
......Rev4 Tbar Turbo......
______Azure blue______
____Project, click me____
Mine just dangles on the vac lines. Soon to be removed I think!
