Temperature Sensor - Gauge
Topic author - Posts: 5
Hi All,
I have just bought an 1992 MR2 T-Bar 3SGE, the temperature gauge does not work on it. I believe it would probably be the sensor at fault, but I cannot seem to find which one it is on the engine, as there appear to be 2 (not uncommon) but cannot for the life of me find any diagrams or workshop manuals with these two sensors. I have attached images below.
I believe the green one is for the gauge? And the other is for the EFI system?
Any clarification would be greatly appreciated, as I said I can’t find this exact setup anywhere in manuals.
Re: Temperature Sensor - Gauge
Hi Jimi,
Can believe I never found that, all sorted now. Just shorted it to ground and the temp gauge went up. So definitely need to replace the sensor.
Thanks again.
Thanks again.
